i read somewhere that you almost never have to pump up past 125 cuz rolling resistance is already close to least amount at 125.
and then something about aero stuffs when above that?
is there any other advantages at all from pumping above 125?
what
What surface are you talking about…
there are a lot of variables in the question you ask.
lol
basically whatever the side of your tire says
air it up that much
plus 30 more PSI
make sure and have your face really close to the tire as you do this
so to hear any superficial leaks
[quote=dooktruck]basically whatever the side of your tire says
air it up that much
plus 30 more PSI
so to hear any superficial leaks[/quote]
Har!
uhmm… this one
is there advantage to pumppin this to max pressure? or pumping any other tire with a max way higher than necessary?
air that one up to 190
lollin’
lolz thanks for protip
maby equestion shoulda been why do max tire presures go up that high anyway?
[quote=kneeeerow]i read somewhere that you almost never have to pump up past 125 cuz rolling resistance is already close to least amount at 125.
is there any other advantages at all from pumping above 125?[/quote]
We have a thread for dumb questions.
is it just me or did the specs on that page say 160… and you’re talking 175? and something tells me you should follow dooktrucks advice
air it up that much
plus 30 more PSI
LOLZ
looks like an answer thanks
hella more protips than i expected thoughHARHARHARHARH
you should straight kill yourself
Great, this fucking place is like brianforums now?
i herd that you sould pump your tires to 80psi, easier to skid with.
according to that i should only pump my tires to 58 psi in the front and then 90 in the back
I never realized I probably need less in the front, I always pumped it the same coz scared of pinch flats in front
ever try climbing on an under inflated front tire
also if i’m reading that stupid chart correctly i should be airing up the tire on my track bike to 150
no thanks
