[quote=EivlEvo]Aerodynamics matters very little in a sprint actually. Your logic is sound, but in a sprint the movement of the bike back and forth essentially completely changes the relative wind from left to right. Unless the bicycle changed shapes while doing that, a LESS aero frame/ wheelset would be better because more of the energy wouldn’t get wasted in lateral drag (which your arms would have to overcome along WITH your opposite leg pull).
So in a sprint, weight (no matter how you want to cut it up) would matter most. Being able to accelerate for a short burst.
I mean aerodynamics would matter to a point, (we’re talking like… a flat plate on the front of a bike vs. a regular frame) but it’s mostly all TT stuff.[/quote]
Word. I should have differentiated between a road sprint, where you’re out of the saddle the whole time, and a track sprint, where you’re seated for the majority.
[quote=TimAlarkey]I dare anyone to try and compute the minute amount of lateral drag that a sprinter must overcome as the bike moves back and forth.
All that lateral drag must be why track sprinters use round tube frames and spoked rear wheels.[/quote]
Re: round tubed frames… have you looked at what’s raced at the elite level? Felt TK1, Bridgestone PHM9, Koga, etc etc etc. Not really round frames by any means.
And spoked wheels? Yeah, at the amateur level. Elite track sprinters ride discs and aero front wheels almost exclusively, mainly the iO/Comete combo.
You’re also assuming that a track sprinter is moving the frame back and forth for the majority of the sprint. He isn’t. The lateral movement is only in the acceleration, and the majority of the sprint is seated.
[quote=TimAlarkey]Aerodynamics isn’t as important in a sprint simply because it doesn’t make as much of a difference compared to a TT. The .01s that you save over a flying 200 turns into seconds on a 40km TT. It could mean a few places in a sprint, but it would mean half the field in an elite TT.
Also, aero TT positions would not allow the rider to safely produce the amount of power needed in a sprint. Too unstable.[/quote]
Dude, it’s all relative. 0.1s may not be significant over 200m to the average person just as 1 second may not be significant over 40k, but it’s still the difference between winning and losing, especially when match sprints come down to the width of a tire.
Also, I didn’t mean to imply using a TT position in a sprint. What I meant was sprinting position, i.e. the position of your back and how low you get on the bike as you sprint. Cavendish has turned it into an art.
