[quote=Toast]Yeah, I realized as I was in bed last night that TB-14s would be the obvious choice. High polish is a no-brainer, yeah (as opposed to hard ano)? I also pondered A-23s or the HED Belgium, but, as far as I can see in QBP, each of these are only available in black.
Hubs… generic Formula/IRO/whatever? Phils would be sweet, but definitely not worth the price increase.
get the tb-14s
and
pauls comp
Please use three cable clips along the top tube. the PO’s use of only two is really grating on me. I like all holes filled, so consider mounting one of those silver bullet rear blinkies to the dangler hanger.
I’m kinda surprised at the separate seatpost clamp, but I haven’t dealt with many 60’s era bikes. Is that stock, or was the original brazed-on clamp broken at some point?
I like those stronglight cranks, but I admit that I’ve always really wanted a set of 3-pin cranks for a SS build.
These cranks are awesome but if you’re putting em on this sweet ass fixie bike and your power legs are anything like mine, you might end up with something along these lines:
That frame is sweet. Fukka centerpull and fukka non-aero. For wheels I’d do something like formulas/open pros.
In addition to the obscure BCD, these cranks have stupid 23mm crank puller threads, or at least mine did. Actually it might be something other than 23mm, but it was not standard. They are really cool looking though.
They’re 23.15mm like all old Stronglight cranks. It was not just a standard, but the first standard — the TA 23mm and Campy 22mm threads came later, in that order. The larger sizes had a purpose, you could use 15mm bolts in them and still fit a normal socket.
things i already have:
-sealed italian bb which may or may not give a decent chainline
-headset
-26.4 seatpost
-team pro saddle
-tt brake cable clamp guides
-brake levers – either 105 aero levers, or mafacs which i got with the frame
things i need:
-formula (or iro, or something identical) to tb-14 wheelset
-bar-stem combo (already have some cinelli combo with approx right stem length, but not sure if i like the bars… otherwise, can do a noodle bar with 26.0 stem, or something 25.4 with a nice flared set of rando bars)
-brakeset (need to measure reach… but prolly going to do the centerpull dealio)
-nice 28-32ish mm tires. or maybe bigger?
-vo fenders
-crankset (still not sure which direction i wanna go, but probably something from one of the shops that sells used stuff around here)
Retro style should never interfere with safety. Silver Tektro dual pivots are classy and perform well. Choosing inferior parts for style is as dumb as riding brakeless.
Retro style should never interfere with safety. Silver Tektro dual pivots are classy and perform well. Choosing inferior parts for style is as dumb as riding brakeless.[/quote]
How many millions of dead people are we talking about from riding Campagnolo or Modolo single pivots?
lulz
if that’s the case, doug can u braze on some disc tabs?
