Add a small solar too
where are we getting dynamo lights from these days? doesn’t look like starbike is the answer
Haven’t done this myself but there are some dynamo lights on the Trek website that I’d be tempted to try while we are in tariff hell
This dumb bullshit still works great.
Question for the dynamo ditherers: I have this baller SON Edelux light with a coax cable plugged into a SON hub. But I’d like to switch to a wheel with a Shutter Precision hub (downgrade I know). Anyone know how I can plug this light in? I can solder something funky if I have to.
You can get another coax plug and just run wires from there to the SP hub Lego brick:
https://www.perennialcycle.com/schmidt-coaxial-connectors-set.html
Kind of an understatement
I’ve only heard of1 son hub failing ever
I like this wording on SP’s website
Big up yuhself
Update that cooler heads have prevailed and I’m using the SON hub wheel.
If you dont mind the 3d printed look you can get a twin usb out dynamo charger for 56$ dollarydoos! That’s probably 3$ US freedom units. I think there is another 10% off if you give them your email or something.
