I do love this XC bike and will miss it.
Size Large. Got it from a tarcker’s buddy. The fork could probably use an overhaul according to the maint. schedule. The tires and wheels were tubeless, tubes now, but I didn’t remove the string cheese from inside. Pedals not included
$500+ free shipping is the tarck deal.
Zhiyun Crane M Gimbal. $215 shipped
Has around 30 hours of use. Selling because we need the next size up. Comes with case, charger, batteries that last about 14 hours.
Dell optiplex 990 with i7-2600 8gb ram and 500gb HDD. WIN10
Just needs an SSD and it’s ready to rip. Haven’t tested 4k capabilities with the integrated graphics, but it does have display port. Not super hopeful… which is too bad. The processor is plenty good enough to run 4k. Mobo doesn’t have pci slot. I’m interested to find out, will run a test if this can 4K. If so, then this could be a worthy home cinema computer as long as you don’t mind your audio being only two channel.
1989 Corolla Alltrac Sedan
~193k, 2nd gear syncro is going out, works fine if driven accordingly. Just started an oil leak after I switched to synthetic Rust Hole in wheel well. and also has some body filler and wreck repair. Clean title. Center Differential Lock. Cracked dashboard material. 33 MPG Oversteers in the gravel, Siq Wip will accept 3SGTE swap. Less than 1000 sedans were imported to the states.
-New Clutch
-New Timing
-New Front Axles
Selling because I unno maybe someone will have time and money to make it the Siquer wip it could be. Posting here because who knows. Ideally this car goes to someone who wants to enter their local stage and sees this as a worthy platform. But probably not because cheaper to go modern FWD
