ohhh, I think I know what you’re talking about. If you strip a little too much wire and stick it through the plastic bit, bend it over and shove it in then the spade pushes the wire out a little bit.
you should be able to cut down the wire a little and hold it taught with your fingernail while pushing it in. That should prevent it from squirting back out.
I didn’t use any shink wrap with the plastic pieces.
I found this photo but I bent the stripped ends over the other direction (U-shaped cutout). Maybe try both and see which one is less prone to ejecting the exposed wire: Lights. by Alistair Spence, on Flickr
Electronics DQ: What is good for cleaning tubeless sealant off of circuit boards and connectors? Alcohol and a toothbrush doesn’t seem to do much, will Windex hurt anything?
Tubeless mounting mishap sprayed Stans all up inside my Luxos U, which stopped working.
[quote=crowding]Electronics DQ: What is good for cleaning tubeless sealant off of circuit boards and connectors? Alcohol and a toothbrush doesn’t seem to do much, will Windex hurt anything?
Tubeless mounting mishap sprayed Stans all up inside my Luxos U, which stopped working.[/quote]
I was actually just cleaning out my apartment yesterday and found 4 different canisters of solder flux remover which might be expired. You’re welcome to give them a try if you want, I was trying to figure out how to dispose of them.
MAF cleaner? Just used some (for it’s intended purpose) but I bet it’d get the job done, safe for electronics, a little pricey, wear gloves - it really irritated my skin.
Is it just the latex covering up the connectors that stopped it from working? How much did you get on the board? I would try mechanically remove the latex first.
Dried up sealant isn’t going to stop the electronics from working. If something shorted out when the sealant got in it then it’s probably too late to fix anyways. To repair water damaged electronics, people generally use distilled water to wash off the salts and corrosion.
I read xylene (goof off) is a good solvent for latex if you try. I have a bunch of dried up sealant on the back of my seattube and BB and it’s a pain to remove. I am lazy, so I just let it be.
It’s really cool, but I don’t really know who that’s for. Like if you drew out a Venn diagram of fast road racing-style bikes with out-front Garmin mounts, and bikes with dynamos, that would be a very small sliver in the center.
My winter break project is going to be a 3D-printed clamp that attaches a Paul Gino to my Thule rack. If that goes well, I’m open to suggestions for other types of gewgaws and dongles.
