Size medium process 134 sold
Parts:
Wheels:
- deore hubs/wtb sti23 rims+discs: $75
- 27.5 white ind CLD/lightbicycle 35mm rims: $550 (note, I mentioned elsewhere I dinged these and filled it with epoxy with no issues in the past 2 years, will take pics if you’re interested)
- Have some used 27.5 tires, I’ll have to take a look to see what is usable and what is done for.
Fork
- 2016 fox factory 36 140mm 27.5 non-boost (steerer tube approx 7"):
$450$400 - Manitout mattoc pro. Currently set 160mm for 26" wheel, have the parts to convert to 27.5 and drop to 140mm. Got it used, there’s considerable oil, not sure if it’s fucked (but it feels alright when I cycle it, the compression damper seems to not be doing much): $75
Seatposts
- KS lev integra 125mm, 31.6 with plain ks remote:
$120$100 (might have an RF 1x left sided lever for an extra $15, but I’ll have to see if they play nice with one another) - Rockshox reverb, stealth routing. 150mm, 31.6, left underbar plunger remote. This was on the process listed previously, sags a bit under weight, probably needs a service, or use it as is. $80
Other
giant contact sl 800mm bars (31.8):$15- raceface atlas bars 785mm kash money: $40 (a couple scratches)
