What’s the cleanest routing you’ve seen? Housing stops or full length? It is for use with integrated levers, so through-stem cap probably wouldn’t work.
I wouldn’t bother with stops.
full length housing > stops
My set-up has worked well: http://velospace.org/files/steelmancrown1.jpg
Routed behind the crown, full housing attached with hydo-style guides and zip ties.
I did see a Vanilla once that had it go into the top of the crown on the left side, and came out right by the brake…now that was nice.
[quote=rudetay]My set-up has worked well: http://velospace.org/files/steelmancrown1.jpg
I did see a Vanilla once that had it go into the top of the crown on the left side, and came out right by the brake…now that was nice.[/quote]
That’s a nice fork. Reminds me to put in a Pacenti order.
[quote=zombie][quote=rudetay]My set-up has worked well: http://velospace.org/files/steelmancrown1.jpg
That’s a nice fork. Reminds me to put in a Pacenti order.[/quote]
Put in a a Pacenti order.
