Yup. I’ve done that exact build in disc and non-disc several times now.
Built a set using some Hope straight pull hubs. I don’t recall the exact weight, but they were close to 1400g iirc.
Use some Sapim D-lights and go with Sapim brass nips with the provided washers and you’re going to have a super nice set of wheels.
The wheels I built most recently with double square sapims were so much more pleasant to build than conventional style nipples.
Question for the pros, if torque is applied on the length of the edge (i.e. the height of the nipple flat) and across the number of edges contacted (max 4 for sq, 6 for hex etc), are double square / sqourx designed to be able to take the ultimate tensioning spoke wrench force on the top square/sqourx section, or is the half height not enough to deal with this? I feel it is, as you get engagement on all 4/6 faces as it’s essentially using a socket (all faces) and not an open ended spanner (2 faces), so if a double height nipple flat is acceptable with a shitty standard nipple wrench torquing on two flats, then half height on 4+ flats is as good or better and maybe as good or slightly worse than a 3-sided wrench.
Edit: TL;DR for the above para: can you bring a wheel to final tension using the top square/hex/squorx part of the nipple or will it round over / shear off?
[quote=Blakey]
Can you get brass sqourx in the US? [/quote]
I think so, but I’m a big fan of the secure lock double square Sapim. Pretty sure they are cheaper too.
For shallow rims the secure lock Sapim hex is my plan B.
[quote=bward1028][quote=Roundabout]Or go four sided like a P&K Lie - plus some TAF colors.
Bought one of these and it scratched the shit out of my rims. Has bare metal touching right to the rim surface. I’ll sell it if someone wants a purple one.[/quote]
Strange, maybe you got a faulty one? I’ve built a half dozen wheel sets with mine and haven’t had this issue, though I do the majority of the tensioning internally when building
Edit: TL;DR for the above para: can you bring a wheel to final tension using the top square/hex/squorx part of the nipple or will it round over / shear off?[/quote]
Should be fine. You have to finish off inverted nipples same way.
