thinking of putting a spare 14T on the other (freewheel threaded) side of my hub so i don’t spin so crazily when i’m riding up there (45/16 is whats on there now)
or should i invest the extra $2 or whatever and at least throw on a BB (right-threaded) lockring? (or maybe a second cog for the same purpose)
or is this a bad idea and i should stick with just the same ol’ gear
Whole thread for this? No, you don’t need a lockring on the track because you don’t need to stop, however if you use back pressure to slow down your cog will come off. Not having a lockring allows one to change a cog quickly.
just buy the spare cog and chain whip that fucker on when you’re going to the track.
you should have a collection of cogs for different purposes anyways if you are racing track more than just occasionally.
Anomaly: You will be fine. Just don’t try sweet whipskidz on the velodrome and you’ll have no problems. If you really care you can do a light rotafix on, but you’ll eventually rape your hub threads if you swap cogs often doing that.
Toast, the fact is that the rule varies from track to track. Most places don’t check for it, even if there is a rule, and some places actively discourage you from using a lockring. My track disc (not some janky conversion, mind you) doesn’t even have a provision for a lockring, and it’s never been an issue at any of the velodromes I’ve visited. They’re pretty happy if you just get your number pinned on straight.
Toast, the fact is that the rule varies from track to track. Most places don’t check for it, even if there is a rule, and some places actively discourage you from using a lockring. My track disc (not some janky conversion, mind you) doesn’t even have a provision for a lockring, and it’s never been an issue at any of the velodromes I’ve visited. They’re pretty happy if you just get your number pinned on straight.[/quote]
Are you familiar with what a spring race can look like?
I’m saying, on a slanted track if you plan on pulling any kind of maneuvers like this, It might be safe to have a lockring just in case. But since you aren’t, fuck it.
even if the hopping around did loosen up the cog (i doubt it) i’m sure it would tighten as soon as they start the sprint. sure that might cause it to slip a centimeter or something, but they don’t have to worry about longevity, just finishing the race.
I’m saying, on a slanted track if you plan on pulling any kind of maneuvers like this, It might be safe to have a lockring just in case. But since you aren’t, fuck it.[/quote]
they’re not allowed to move backwards, so any noticeable backward motion would stop the race before the cog had a chance to come off.
(yes? dq or restart? someone who knows more than me.)
