Today I became the customer I hate and asked if I could show the mechanic how to install a crown race, after he started it crooked and removed it twice. At least now they know the bench vise also has an anvil.
Doing some Sram surgery right now, is there an easy way to remove this pin that retains the brake cylinder cover plate? The rebuild kit has a thicker design for the plate with a hole for the pin so the pin goes thru instead of the plate tucked underneath it
Okay I got it out with a punch. Glad my neighbor had a set I could borrow
The replacement cylinder kit has a longer spring in addition to the thicker plate, getting the holes of the plate lined up with the shifter body is annoying and you need 3 hands, one to push the plate down and aligned, one to hold the punch, and one to tap it in
Also seems like the caliper pistons really needed to get greased up, one of them was doing all the movement initially
