I’m amused by the shit brake honestly, but not surprised there’s zero wear on the rim sidewall.
The tire still has tire powder on it. The background is probably RedBullTV.
My kiddo’s SuperSix has a 9/8-5/4 tapered headtube.
For a reenactment build, I guess it’s OK. Finding parts is kinda limiting, though. 5/4 stuff was hard to find even back then.
I had this thought years ago and even bought an acros 1-1/8-1-1/4 EC37 headset to do it. Never got around to buying a 37mm reamer though and now that Im mostly interested in building with aluminum the main tubes are so fat there’s no point.
What is this
I remember making fun of it so now I obviously want it
Basically knards
see also @marcsworks mon-cheri
Oh yea mon-cheri are great, triangles are much cooler. 3d printer and a little grub screw will do.
I should make a tarck bear this weekend or so.
needs to be a slice of pizza
Tiny reflective safety pizza
its basically a black mountain cycles frame but 2x as much and with worse welds?
It’s Columbus Life tubing so not quite
2
its a crosscheck with limited edition buttway?
You leave the jackalope out of this.
musa is dead. RIP musa.
what this does not mean is cheaper bags, most likely.
