i need a long reach brake for my new build, but i’m broke now.
so on the brake i already had, i filed the parts that hold the pad into the caliper down as far as i could to get the pad to slide down farther.
is this enough contact on the rim?
i’m thinking that as long as it’s not rubbing the tire it’s fine.
am i right?
Just file it further if you’re not happy with it. Slot it out completely.
The bolt itself will hold the two sides of the arm together a lot stronger than the actual Al “bridge” ever could, so as long as a good part of the washer is making contact with the arm you’re good.
I’m too lazy/busy to dig it up but sheldon says so somewhere.
i think you’ll be fine, but i would also like to see that rim after a few trips out with the brake. something tells me you will be using it only in ‘oh shit’ situations on that rim, so if this setup is going to fail you may have bigger problems at the time anyway.
