I think general consensus will be that it’s fine with a bit of dissent that it will look like shit, slightly less stopping power, a reason to machine rims is to make the braking surface perfectly level, etc.
You will still need two separate rims. unless you know a trick that the rest of us do not. This is why it is called a bicycle. bi = two. In this case you cant use just one. …
