im putting the 09 rival shifters and derailleurs on my bike now. roomate rode them for a day and decided to stick with his da.
so, brake lines and position are set up, all thats left is derailleur cables, because roomate sucks and frayed the shit out of them, so I had to get new ones. these things are next to impossible to get back in the shifter. anyone done this before? I just cant get the cable to go around the turn inside the shifter. called sram and some chick on the phone said ‘‘well they should just slide right through (very hesitantly)’’ Well they aren’t.
anyone got an idea. might just go to a shop, but its pouring outside now id rather not.
if you want to check out the 09 video for sram installament, here it is: http://willyoumaketheleap.com/ go to -service- up top, then the -controls- video
they always come preinstalled with both cables but the roomie fucked them up, and the way it works is where you see him pop the head of the cable out, it goes under the shifter then around and back out the top. my cable keeps hitting a spring I cant seem to get out of the way for anything, and just wont bend up. tried curving the cable a little bit but I dont want to fray it.
Ben, these are ALWAYS a pain in the ass. It helps to remove those three little screws and take the cover off the side of the shifter. Then take the end of the cable and bend it a bit to give it a bit of a curve over the first 3cm. That will make it easier to slide through the shifter body and having the cover off makes it easier to see if the tip is actually going into the shifter body correctly. This will still require some cussing though…
Yeah, this always takes FOREVER. I think I figured out that certain cables are manufactured a few micro-millimeters larger in diameter than others, and those cables won’t fit through. I actually pulled apart the frayed end of one and counted a few more individual strands than on the ones that fit in my Rival shifters.
i screamed ‘baby bitch’ at jim beckmann 3 times and actually got the left shifter through. this took alot of patience and is something i never want to do again. now the right…
just take em off, take off the guides and use the bosses to mount downtube shifters.
hoo ah! your good to go, I’m thinking about racing this spring on tubulars and an 80’s landshark with dt shifters and moustache bars for collegiate club.
getting the shifting set today by a shop. got the cables run through. it is obviously not shimano and i need someone else to set the derailleurs. springs are crazy.
