I got 27.5x43 at 480 each
700c 45mm deep are 486grams. 26mm external.
650b 32mm deep are 365grm. 32mm external.
Bought the 34 external 650b rims in 32h and 28h sets, then panicked that they were too wide, bought a 28 external 650b 28h set, and now the road set since I realized I got hubs. So 4x unless they send me something wrong.
oh i didnāt realize those came in 32h oh well.
i might get some road rims to hoard. why not
That makes them not much better than light bicycle. Anyway, now I need to save money to hire fergs architect friend ![]()
Right on. I hadnāt checked LB prices. I got my 650b rims for 30 bucks, so I was content. Though that is supās enduro bike at this point and could get Spec rims in 28h for less than these at 50% off, too. But also donāt need to sink money into that when the move will take monies, too.
OK, can someone make a cheat sheet for the pub rims? I wanna join in the bad decisions and put a few rims in my already over packed bike room.
What are the options for 700c? I see the rim brake jawns but 17mm is far too narrow. Anything 23-25ish? Want a stupid carbon tracklocross wheelset.
The interesting 700c i24 rims would be the gravel jawns which are more expensive, but still a ~50% discount from comparable options:
There are a few newer i30 progressive options but they start at over double the cost of these discounted jawns: NEXTIE - Gravel AGX Series
I already copped the 650b variant which is more like i25 wide, and has a really nice molded valve hole to have a strong flat surface on the assymetric profile:
canāt fucking help it can I
someday Iāll rebuild my Time SONXS dynamo wheelset again for the last time with these road rims
Iām holding out for TAKE75 before I hoard more rims
so as a degenerate who bought 28h rims:
15/100 CL front hub has an SLX, XT, and dt350 option
qr/135 CL 11s rear hub⦠origin8 and onyx? 350 should be an option still but I donāt see it
for the dt350 rear with a Road 11 freehub you would buy the 142/12 version and swap the endcaps for QR
oh, yeah it makes sense that the spacing would also change. thank you
have you tried aliexpress yet?
iām pretty sure i actually have these endcaps in stock. but that gives me other ideas since i have a 135 qr bikeā¦
I looked a bit ago and thought I found what I needed but I was mistaken
Bro I got u endcaps
you found them? Iāll find some 350s then
