Endpoint bikes thread
Yeah. Need some of this.[/quote]
I haz, but no money in it.
My individual account has like $4 in it. I’m afraid to even buy a coffee because I don’t want to trigger the overdraft protection.
A caliper question: have you considered the trp spyre over bb7r?
Lighter, dual piston, similar price. Downside is I guess it’s not readily available yet
only thing holding me back. as soon as I get my hands on some I’ll make a decision.
Will spec the shimano calipers with the shimano build though.
QBP says no stock til mid June. Will probably price things out with Avid and IF they come in and IF they don’t suck I can always change.
Also:
Does tubeless matter? Considering going with American Classic 101 rims on the Force build and sticking with Archtype for lower levels (or 101 as upgrade). They are lighter (70g less per rim than Archtype), don’t have the max pressure problems with tubes that Stan’s rims have, and work very will for tubeless cross applications.
2 downsides: slightly harder to change a flat if running a tube, would increase price by about $40
only really harder to change a flat if you’ve depended on the tire/rim interface being loose like sleeve of wizard
I like the added bead security and it’s saved my ass a few times in the gnar
the AC rims look awesome, they’re my backup plan if the chinese crabons + hetres don’t work out
Email sent.
Did you design the geo with a specific fender in mind?
As for tubeless/not: who do you see as the main person buying one of these? It seems like a bike nerd’s wet dream bike to me, so from that end I think the kind of person interested in the frame would probably be the kind of person willing to deal with / wanting to go tubeless.
[quote=Bahamontes]TC: I budget every month using cash and envelopes (envelope for utilities, rent, entertainment, vacations, etc)
Last night, Ashley comes to the balcony where I’m enjoying a glass of bourbon. Looking at me ever so sweetly, she calmly asks,
“What the fuck is an endpoint and why are we saving so much money for it?!”
I replied, after a good swallow, “Cause I’m getting the Force build.”
:bear:[/quote]
POTY
[quote=Dirty Sanchez]only really harder to change a flat if you’ve depended on the tire/rim interface being loose like sleeve of wizard
the AC rims look awesome, they’re my backup plan if the chinese crabons + hetres don’t work out[/quote]
eeeeaaaaaant. wrong.
I’m sorry the answer we were looking for is that due to the inner ridges on the AC rims that are designed to sandwich the bead between them and the hook (and to avoid stan’s patent) it takes a far greater amount of pressure than expected to fully seat the tire when changing a tube. Has nothing to do with actually taking the tube in and out. Can prove quite annoying if you are using a hand pump on the side of the road.
I have built up a few sets of these now for customers and shop bros, some for trail use and some with wider street tires. I have mounted several tires in the 700x28-35 range with tubes when setting base tape and mtb tires as well. In most cases it takes well over 60psi to get all of the bead to seat with or without soap.
Also re: Hetre X China carbon collabo… good luck. I have a few of those rims in now and have built up one pair as 29er trail wheels so far. Tire/rim interface is OK at best. Bead does not lock into place nearly as well as Stan’s or AC rims. The 650b rims I have from the same place don’t look like they will be any better for this purpose.
Feel free to actually try it and prove me wrong.
Dgaf re tubeless one way or the other
Does this thing have 650b potential?
no.
650b bike comes later
DQ: Apex or 105 build for better disc brake behavior?
i don’t know dick about dick brakes, so this is relevant to my interests
It’s all in setup atmo.
Both the shimano and avid ones work great with compressionless housing and proper attention to setup.
[quote=bradencbc]no.
650b bike comes later[/quote]
Is this something you feel at least 65% confident about? Because that sounds maybe more up my alley…
65% is reasonable.
I want to make one.
wrong thread
fack, stan’s rims are already annoying enough to fully reseat the bead on trailside without Co2, having to inflate over 2x would drive me crazy
guess the Arch EX is my fallback then
[quote=bradencbc]Also re: Hetre X China carbon collabo… good luck. I have a few of those rims in now and have built up one pair as 29er trail wheels so far. Tire/rim interface is OK at best. Bead does not lock into place nearly as well as Stan’s or AC rims. The 650b rims I have from the same place don’t look like they will be any better for this purpose.
Feel free to actually try it and prove me wrong.[/quote]
light-bicycle changed their design for the 650b ones, will see how that pans out
The bead shelf is def tall enough that you can’t get a tire mounted without pushing the bead into the center channel the whole way around. The bead hook isn’t as short as it is on a Stan’s rim, but that also means a split-tube rim strip remains an option.
gonna be lacing them up tomorrow
Post pics and measurements of the inside of that rim. I have some here too from a different distributor I want to compare to. The 29er ones I got are the same thing for sure.
