FACE 2024 PARTS PURGE OF GREAT IMPORTANCE
Yo, buy my old shit, ask me questions about it and I’ll answer to the best of my sass and ability. Whatever doesn’t sell here goes to marketplace or ebay or something, gotta make rent y’all.
First up, STEMS. I can eyeball the angles if ya want.
9/8, 110, 25.4, $5
9/8, 130, 25.4, $10
9/8" threadless adjustable stem riser, bearing preload set on that little collar, came on my cargo bike but I swapped a longer steer tube. removable shim on top to run 1" threadless stem. need to remove star nut, may only work on steel steer tubes. $5
OEM Specialized adjustable angle stem, 9/8, 110, 31.8 sold
Bolts have a little surface rust, 9/8, 110, 31.8, $5
No hardware, appears forged, light OEM takeoff, 9/8, 110, 31.8, $5
8/8, 90, 26?, $10
Same as above with red face-plate but with hardware, $10
8/8, 100, 25.4, $10
9/8, 130, 25.4, sold
9/8, 100, 25.4, $5
Stay tuned for more.
Next up, some hubs
36h, sold
20h ZIPP, sold
32h, $10
32h, NOS, lots of shelf wear. No longer for sale, I’m lacing them up.
32h, 130, 8/9/10s, sold
2 for 1, cracked flange on shimano hub, campy hub is ok, take both. campy hub is 24h, shimano is 32h, both 130, sold
DT Spline, scuffed and spray painted black, all paint that has chipped off after it was unlaced and spent a few years in my parts bin. 28h, 142/12, $20
28h, 142/12, sold
Some more other shit
One has a little rattle you can hear when handling the bike but cant feel when riding. $10
Well loved, $5 with or without toe clips
One, tire, one ride, the other one caught a huge cut, $25
$5
$10
Used Sram Red front flat mount caliper and pads, cracked lever body, never crashed, never came loose. I was gonna sell the caliper alone for like $40, want the lever too?
$1 each
Takeoff for a power meter, low miles, full maintenance history, $1
I used to collect these things but they no longer fit. I probably have a few more stashed away somewhere. $10
This ain’t a great light set but it sure is a cheap set. Sold
$40
Made from recycled tradeshow banner, $5
11s left, $5
Sold
Drilled to not block bottle boss when using cross rings. $5
$5
No idea what it fits, $0
sold as lot, $10
$25
“Red” $5
works, $10
High performance, $1 each
It’s rubber bar tape that has built in end plugs and no adhesive. $5
8s, $20 pair
$10
$15
$5
$5
$5
$5
$1
$5
$35
$5
$5
Sold as lot, $10
Sold as lot, $1
I’m your huckleberry for that weird di2 shifter; where to send moneys?
I’ll set it aside for ya, please hold the line, more coming.
Indicator removed, $5
$1 each, no bulk discounts.
Cane Creek 40 lower bearing, original upper, $20
$15
Kids?, $10
$5 each
$6
$5
It’s got that one ding on the seat stay and a few scratches, big boy, $200
Someone spray painted it before I got it, you can probably get it off with oven cleaner. $75
XL, ~64mm steer tube available for headset, small spacer, and stem, Seven takeoff fork.
Tried this thing here before, gonna go try the retro nerds on facebook.
Some bars, forks, fenders, and a rack coming later today or tomorrow.
I got this hub in 32h if that works for your needs?
Have you actually ridden the Outland VPP? Is it broken or anything?
My friend bought it new and raced it downhill then it got transformed into a trail bike then hung on the wall when the new thing came out. As far as I know the only issues it may have are with the age of the seals in the shock and fork. I’ve compressed both and they both moved as they should a few years ago.
Any idea about sizing?
Yep, I’ll take measurements today. My bud that rode it is like 6’1-6’2.
Dibs on trp drop bar levers
Taking back dibs
harumph I do kindof have a build kit for that
Do it before I peel the tarck stickers off and toss it into the void of marketplace.
Shrink coffee grinder to medium plz
I got a 50mm stem somewhere
st, c-t: 18.5"
tt, c-c: 22.5"
ht: 5.75"
cs: 16.75"
