I found a pair of wheels the other day with old Normandy hubs I’d like to keep. Rims are junk. Anyways, the back has an old Maillard freewheel that I need to get rid of before I can cut the spokes. I’m wondering if an of you geniuses have any tricks to get this thing off without buying a tool I’ll only use once. If not, I guess I’ll just bring it into a shop.
You need too much force to use anything other than the tool. Pretty sure Barnetts has instructions for removal that destroy the freewheel, but I think it’s more trouble than just doing it right.
The one I destructively removed had a lockring. It’s not like a cassette lockring. Maybe lockring is the wrong word… it’s a ring that holds the shit together though.
This doesn’t look like it has a locking outer cog like a lot of older freewheels have. As you suggest, and by the look of the splines on the inside, you’ll need a proprietary freewheel removal tool. The Maillard freewheel looks to be an odd size considering the 23 splines. I thought I had an old removal tool that would work, one I could have mailed you perhaps, but it doesn’t have enough splines. Sorry.
That Maillard freewheel uses a helicomatic setup. You need a specific tool, and the hub is made for that freewheel. I had to deal with one when building a cruiser for Amanda. I just bought a new wheel.
Helicomatics were a proprietary system. This is just a standard Maillard freewheel on a Normandy hub. You can tell cause it doesn’t have that weird ribbed lockring.
