Clearing some room before sup wife and I acquire a new house. I’ll keep posting as I get through my messes.
Bridgestone T 500
Was my college bike, and I’ve held onto it for years even though it’s too small. I had the rear canti mounts moved to spec for 700c, then returned it to the wall to hang as it has for many years. Original fork was tweaked when I got it, so it has a replacement, though the original will be going with it. $100+ship?
Surly Straggler 60 cm, frame, seat clamp and headset. Was my setup for a Clydesdale build, but after inheriting Rustys extra cycle kit it’s been sitting unused. A few scratches from lockup but no dings or dents. Keeping the Clydesdale fork for future dithering.
$200+ship? Accepting all reasonable offers on everything I’m listing.
If you don’t care about weight just use like 1/8” mild steel and the metal hot glue gun. Get your framebuildeur to extend a bmx fork steerer and machine the headtube extension.
I did a steerer extension a little while ago for someone. I tigged it but you could probably mig it (not fluxcore tho) since the weld gets ground down anyways and it’s relatively thick material. I just copied the technique Brodie used in one of his YouTube videos.
IIRC one of the secrets of the cycletruck conversion kits was the bulk purchase of 9/8" threaded recumbent forks, which got their steerers chopped and extended
