I’m getting prepped to redo some drywall in my garage and paint, so it would be really kind if people would buy some of the bike stuff currently taking up space in my garage.
Road
Di2 6870 build kit. Taken from my road bike, this kit has been raced for a couple seasons, and isn’t in the best cosmetic shape but works great. 6870 front, SS rear derailleurs and shifters. 5 port front junction, wires from a 58cm aero build. Internal battery. $500? and I’ll include the Bontrager RL aero 42cm bars and a stem. No crank currently, though I do have an FSA gossamer or Rotor 3D+ SRM that we could work out a deal for.
Tune Mig/Mag to Pacenti SL23 v2.Set up tubeless with Schwalbe One 25mm tires and American Classic valves. maybe 500 miles. 20/28, built with sapim cx ray (nds) and cx sprint (ds) spokes and aluminum hex head nipples. $450 with tires?
Cross
Di2 R785 hydraulic build kit. 6870 GS rear and front ders, R785 shifters and calipers. 3 port front junction, internal battery. Wires from a 58cm frame. $500? and I’ll include Bontrager RL aero 44cm bars and a stem plus any of the random items listed below.
Yishun carbon rims (edit: 24.5mm depth, outer width 24mm, inner width 19mm) to Novatec D711/2SB hubs, 28/28. Currently set up for QR but can be converted to TA with purchase of endcaps. Built with Sapim cx ray/sprint spokes, same as Tune wheelset.
Stems:
- Zipp Service Course SL, 120mm. $40?
- 3T ARX Team, 120mm. $35?
- 3T ARX II Pro, 130mm. $25?
- Ritchey Pro old man stem, 100mm. $free.99?
- Seatposts:
- FSA K-Force 27.2mm Di2 compatible. $70?
- FSA K-Force 31.6mm in Cannondale green. $50?
- Race Face 30.9mm x 375mm. $10?
- Bontrager XXX 27.2, seatpole portion is fine but needs new clamp hardware. $5?
- Cranks:
- FSA Gossamer BB30, 53/39 175mm $30?
- Rotor 3D+ SRM power meter with 53/39 Praxis chainrings (under 1000mi) and recent battery replacement. $450?
- Saddles:
- Ergon SMR3-S Pro Carbon saddle (used for cross bike, 9/10 condition), black. $70?
- Dash Strike, stock, black. Some scratching on one of the rails. $100?
- Adamo Attack, black. $60?
- Random:
- Rockshox Reverb bleed kit $free.99?
- Tektro T750 direct mount brake $10?
- Tektro T925C direct mount brake. $10?
- Bontrager Speed Stop direct mount brake. $60?
- Niterider 350 front light. $15?
- Garbaruk 130BCD narrow/wide 42T oval chainring w/ Wolftooth single ring bolts. $40?
- XT PD780 pedals. One doesn’t like to stay super tight to the axle but I haven’t done any overhaul or tried to fix it. $20?
- Rotor BB1 ceramic BSA road bb. $30?
- Rotor BS30 bottom bracket. $15?
- Wheels MFG PF30 outboard bb, used. $20?
- Sram GXP PF30 bb, new. $15?
- FSA Pressfit 30 bb, new. $15?
- FSA 24mm reducers, new. $15?
- FSA MegaEvo bb, installed but never ridden. $15?
- Pair RT-81S Ice tech centerlock rotors, 160mm. $40?
- Light and Motion vis 180 pro tail light, $40?
Light and Motion vis 360 helmet front and rear light system, $60?
