Cannondale M500 1996.
22” Size. Saddle height as pictured is about 735mm.
Color is Moss Green, which is very dark and almost black in some light. The fork is from a same-year KillerV 900, color Black Gold.
Small dent on the underside left side of the top tube, likely from handlebars of previous owner. I currently have the TT wrapped with bar tape in a different spot to protect from the current bars -there is NO denting under that tape. The close-up of the dent shows it in the worst light, if you look at the whole-bike left side pic you can hardly tell where it is. There is a tiny bit of tire rub at the left chainstay, and other general paint damage from cable rub, etc.
Single speed via magic ratio method.
Frame/fork $65
XTR brake levers and V-Brakes. $50
Surly SS disc hubs 32 hole to Sun Rhynolite rims. Rear bolt on, front red Salsa Q/R skewer. $50
Bontrager XR1 26x2.4 tires(tubed) $50
Crank is a Cannondale CODA Tarantula 94bcd double, set up single with a 44T non-ramped Salsa chainring. $30
Shimano Ocatalink V1 “road” BB $2
18T ACS Crossfire freewheel. $10
Control Tech seatpost (27.2) $20
Control Tech stem (1-1/8”, 25.4, 90mm) $20
Answer riser bars. $10
Wellgo MG1 pedals. $10
Rockbros saddle. $5
SRAM lock-on grips. $5
Chain. $1
Seatpost clamp. $1
FSA Pig DH headset. $1
bottle cage: $4
Price: $SOLD to a local
I will possibly part it out if you want a bunch of stuff, but trying to sell it whole.
ALSO: I’m open to swapping parts on/off of it to your preference. I have other 27.2 posts(black or silver), square taper crankset, flat bars(both really nice vintage and really cheap), 31.8 riser bars, 31.8 stem, Deda smoke gray stem + smoke gray 27.2 post, Easton riser 31.8 bars in gloss white. I can pull the white pedals/grips/saddle and swap on something equivalent in black. SRAM X9 shifters and derailleur. Cheaper silver v-brakes. Middle-of-the-road Avid levers and Avid v-brakes. I have $free townie tires that I’d swap on. Silver V-O fenders. Black Electra fenders.
