If you are not on the aeros, for sure. You are practically a windsock. I always have aero-bars on.
A few tri companies allegedly designed their bikes around ā€œage grouperā€ speeds for this reason.
Randonneurds should absolutely be thinking about this if their goals include anything beyond ā€œdoing it just becauseā€. 7+ hours is a long time and those marginal gains have quite a while to start stacking up.
I feel seen
I’m not a randonerd and I’m not super fast but I do ride long and I firmly believe in taking every last marginal gain I can. Also I find grubbing for watts kind of fun
I don’t follow? ā€œdoing it just becauseā€ is why I do it, but that doesn’t mean I’m planning on puttering along at walking pace while I’m doing it.
Then you’re doing it for more than ā€œjust becauseā€. Just because is an excellent place to start. But if you’re thinking about your speed or how long it’s going to take, or how long it took last time and maybe taking less time than that time before then you are already going down the rabbit hole. You know Conti makes skinny 650b GP5Ks right?
You also have like 20cm of saddle to bar, so you’re ahead of 99% of randonerds.
Speaking of GP5K I just saw that the tan TLRs are…99 USD?!
I’ve got a bunch of them at home, and that’s what the upcoming disco frame is going to be built around, so, yes, I’m aware :-)
See. You want to go faster.
It’s more that I don’t want to feel like I’m oozing about on a bed of slime.
Article came out but it’s Pro only and the four tires aren’t added to the regular listing.
Kinda surprised just how fast the EL casing is. This is the largest gravel tire BRR has tested and would rank #2 if the EL model was added to the full chart, 2nd only to the 32mm GP5k. At actual riding pressure, it would be around 5th place.
WTB gave me 40% off of a new set of tires for my troubles. Went with Nanos with the extra puncture protection. Prob a little overkill for Rock Cobbler, but should be decently fastish.
I’m still waiting on my order from Bike24.
Damn, you ordered almost a month ago, right?
Yep. Have spent 2x as much on tires while waiting.
If I’m planning on commuting on a set of runny arse tires, should I spring for the endurance or endurance plus casing over the standard?
I have their knobbies on there now in the regular casing and they haven’t been the flat magnets I expected.
Or is there something else in 700c x 40-45mm smoothish tread that I should consider.
if you’re just doing utility commuting on this bike, why not Schwalbe Marathons or their bigass cargo tires. Probably no good if this is partly a fun bike, but otherwise, it’s hard to beat them
So many hills. I don’t want the weight penalty and when I had big apples on there it felt like it took forever to spin up.
I’m probably not riding through any of the really bad glassy sections of the city and I still have to carry it up two flights of stairs
Yeah fair, I used to commute from Hayes Valley up and out to outer Sunset, is no fun with big tires. Maybe a middle ground between paper thin and moped tire? If you want to go big, Conti gp5k tr are pretty awesome and basically never flat
I ran the standard casing 38mm guys setup for tubeless for quite some time with no flats. Probably a few thousand miles on Oakland streets. They didn’t seem especially delicate to me.
