Few folks around here have em and they look pretty silly IMO
Ok so i just mounted the GKās (48c) holy fuck this tyre is hard to get on the rim
Had one of those perfect tubeless success experiences.
Ran over nail
Removed nail
Rotated tire so hole was facing down
Sealed up immediately
Didnāt lose enough air to compromise tire firmness
Continued riding
bless you
Have done about 80 miles of gravel and single track in the past few weeks on the G-One Speeds.
Theyāre not as nice on gravel as my beloved Thunder Burts, which is to be expected, but traction was surprisingly good on loose dirt and rocks. Def appreciating the beefier sidewalls as compared to Compass Tissues, I descended without worry on some sharp nā nasties and noticed a few scratches that would have probably been tears on a Compass.
The one down side Iāve noticed is that the G-Ones seem to have a narrow band of PSI goodness. Itās easy for them to feel too hard, and if you knock them down too much theyāve got a mushy shitty feel. Iāve been keeping mine (2.0) at around 24-25psi and that seems about right, lower and they start to feel no bueno - I weigh 140.
Just gonna, uh, leave this here
Iāve been pretty happy with the longevity of both my rat trap passes and my grand bois hetres (obviously not compass)
so maybe heās not completely wrong here.
Hetres die only after the sun deteriorates the rubber enough for road hazards to cause damage. At least 1 year no matter the mileage.
I bet you can get a fair amount of miles out of Compass tires but I do kinda wonder how long Jan will run them in flat-magnet territory. Though I feel like weāre supposed to believe that he doesnāt get flats
His basic point is probably right: wider tires probably wear out more slowly than narrower tires under similar use cases.
Sure would be neat if he disambiguated his blog from his company, or brought BQ, Compass, and his blog under a single brand. Nothing wrong with a brand blog.
yeah, Iāve been pretty impressed with how long my Snoqualmie Pass tires have lasted.
I did kill one with a nasty sidewall slice, but thatās my own damn fault for taking a supple tire down some rocky singletrack.
yeah the rubber was too thick, which then accelerates the sidewall wear from flex
and also makes them slower because the tread is stiffer
Has anyone tried making some silk fatty tires? Seems like that would be the baller high dollar sidewall choice.
Whatās a good alternative to the Hetre? Something supple but a bit sturdier than the Babyshoe EL? This would be for road/dirt road touring, commuting, some spirited riding. No PVD-style āgravelā.
Thereās the non-EL Babyshoe, obviously, but what else is in the same category rather than much-sturdier gravel tire?
the Horizon is pretty close to a modern-construction Hetre, tubeless and slightly bigger
thereās also the G-One Speed that comes in 40/50/60mm to fit whatever fenderway
have you been on the g one speed? can you comment vs horizon? the 48 gravel king is, in fact, a terrible tire and i think itās gonna get me hurt
Is there a source for cheap G-Ones from Euroland? I was thinking of getting a pair for exactly the reason you mention (something kinda knobby that fit with fenders).
How about that 400 gram 27.5x2.0 Schwalbe G-One Speed that is Liteskin not Snakeskin? Wonder how tubeless it is (not a TL-easy tire) and how durable compared to an EL Compass. I find it hard to believe that they are incapable of making a TL tire between the 400 gram and 500 gram mark. Really takes 1/4 pound to TL a tire?!
https://www.schwalbetires.com/bike_tires/racing_tires/G-ONE_Speed
I also see that the 2.35 and the 2.0 weigh the same because the 2.35 doesnāt have āv-guardā Seems like the 2.35 tire in 2.0 would be perfect.
A 700x23-28c tube weighs about 100 grams for reference.
Just wanted to say that I am really loving my Marathon Supreme 700cx42mm tubeless on the back of my LHT. Looks like itās going to be durable, tubelessād really easy, rides nice, feels fast and still has confident grip in the wet. Not exactly weight weenie but Iām cool with 600g given all the upside.
All that being said they appear to make that tire in 650bx42 but not in tubeless? Iād have to assume that a bigger and/or tubeless version has to be in the pipeline but I donāt see mention of it anywhere yet
