…and you have no place to mount the clampers
I have a DT hugi on gf’s m2. It has the slowest loudest freehub ever. Makes it easy to keep track of where she is
someone here has turned some of these to be regular non-disc hubs
Pretty sure you can still find those ultegra to open pros that were everywhere for awhile. Would look rad and have the right spacing. Also, cup and cone to scratch that self service itch.
i’m over cup and cone tbh.
dt swiss 350 is ultimate self service. wipe and put grease in every ??? months. done. i’m at 8 years with not-insignificant mileage and it’s butter smooth. i’d gladly pay a shop every decade for new bearings and i worked for a long time as a bike mechanic
My pandemic build has a 350 I bought at 130 cause no disk mount and I got the cups to space it 350
Oh I 1000% agree with you, but @Orloved seems to be rather fond of older gen objects.
I only build dt350 on everything, so damn smooth and reliable.
You’re joking right.?! I’d say 90% of the people here love a good kludge.
Fixed it.
Certainly there must be some caustic solution you can apply to the black one to make it silver-ish and steampunk looking?!
This is making me request an agreed definition of kludge
Which is a non insignificant portion of the bicycles on this forum. Not that it’s a bad thing we just make things work with things that are not designed to work with another.
Any parts bin build could be labeled as a kludge.
Hamfisting a too big a hub into a frame which while it fits the definition of a kludge is more like tomfoolery or shenanigans or idgaf I just want to ride it. All of these things are OK.
I’m only here for the kludges. Throwing money at a problem is lazy.
Kludge defines everything I have ever done with bikes. I think it’s in my genes.
Sometimes I’m here to learn which kludges pan out, and when it’s better to just throw money at a problem.
if anyone is curious I emailed Johnny Coast here in Brooklyn and received this sage perspective on cold set vs just buy a hub:
and, if you trust yourself, just bend the rear end yourself… or keep searching for the proper hub width, my actual advice…
Good luck!
this thread is supposed to be a safe space for kludging
ATMO an electrical conduit bender works great for cold setting. That lets you put the stress away from any dimples or bridges. Go slow, like 1/2mm at a time, rotating around the four stays. Threaded rod is strictly bush league
Wouldn’t threaded rod be right at home if this is a safe space for kludging?
That’s how I’ve kludged my last two bikes with various degrees of imprecision.
I have a set of drop out alignment tools your welcome to borrow if your set on this course of action
