Everything FSA sucks, period.
if i got that chainring id powdercoat it to match my veeeez.
lately ive been lusting for a modolo stem:
That was definitely a 55T ring though. It would be kind of hilarious to push that through the city.
How about some CF cantis?
Because, you know, normal cantilever brakes are so GD heavy.
^that picture got me so confused
Me too⊠Whereâs the rest of the bike!?
2009 Super Record Groupo!
http://link.brightcove.com/services/lin ... 1655754222That sucks. I havenât even gotten a 10spd bike yet, and they already have 11âs.
Edit - I donât really dig the fact that the BB Bearings are oiled rather than greased, and I especially donât dig the fact that you apparently need an 11spd specific chain breaker. Itâd be great if things were getting simpler, rather than more complicated.
âfor climbin upa da hillsâ
11 speed makes my brain hurt. 10 speed chains wear out fast enough, thank you. Finally something new for the investment banker set.
they are building the rack.
the fork wheel and fender is used to make sure everything clears.
Donât you need a special tool for Shimano 10 speed anyways, because of the peening?
This is why we ride fixed gear.
Unless you consider matching Deep-Vâs to your dunks complicated.
tarckbear smiles down upon you.
Donât you need a special tool for Shimano 10 speed anyways, because of the peening?[/quote]
This is basically the case with all modern chains, except the cheap KMC Z stuff. Itâs largely irrelevant though, because you can use your standard Park chainbreaker to push the pin out, and after that you just use a master link.
^^^ how often do you break road chains? I mean, Iâm no really experienced road bike mechanic, but isnt the point of buying a chain that fits your gear number (6,7,8,9,10, etc.) that you dont HAVE to break it? or am i just fucked?
Yeah, I donât see why you would be removing it unless youâre replacing it. Someone will come along to argue that if you pull it off you can clean it better, but the benefits are marginal and in my opinion definitely not worth the hassle/damage.
