Here’s the link. Right now the badge itself has an ID of 33mm (to account for paint and VHB tape), which should work on many bikes that have a 31.8mm-ish OD head tube for a 1" steerer-ed fork.
(I can make other diameters if other folks are interested)
Just updated it to have a bunch of different colors and materials available.
I think @Mister_Uncle_Rudy 's is made from “polished bronze-silver steel”. Previously that was the only material other than pink plastic.
Let me know and I will update to any/all of the other materials shapeways offers if you want something else.
Can I ask a dumb question, how does Shapeways work?
You upload a design, add a possible markup for your design, then they handle the print and ship with their own markup added?
This is cool. I might get one of these but also thought it would be fun to do my own with part of my logo. Fired up Fusion360 and watched some tutorials. SENKO “S” headbadges will be an option now!
.02" - .025" thickness tape should work fine. (.6mm). I’d go for the “foam” type so there’s a bit of give.
Or any thin good double-sided tape you could use a couple of layers to build thickness if you need it (depends on how thick the paint is on your head tube, etc.).
Stick to the back of the badge first, use an exacto to trim the edges off.
If you can’t find a roll for sale at a reasonable cost, ask around a signmaking shop if you can get a few inches.
