VO post has extra setback for Brooks friendliness. Sure you could go cheaper with the stem but polished silver looks nice and more matchy match. Black parts will get scratched up if they’re packed a lot.
Where are they traveling to/from? That’s a lot of $$$ to lock up while you’re going into some restaurant in a third world country or a city with a questionable crime rate.
Especially if it’s a coupled frame.
Unless they aren’t gonna be locking them up anywhere, then go baller with your baller self.
I think Dimension makes a stem that’s identical to the VO stem. In any case, you’ll need a 26.0 stem which a Thomson X2 isn’t. Definitely a VO stem would be prettier. You’ll also want a VO seatpost as mentioned for the Brooks.
As Amy stated, Rival definitely comes with a shim.
Also, do they need/want brifters*? Bar-ends would work for this kind of build.
Having qbp means you can get dimension stems for like $10. Greg, is that QBP open in Ogden yet? I would consider moving to slc/ogden if I could get a job there.
i don’t think i’d wanna ride 35c randonneurs, my understanding is that there is a world of better tires out there. but i’m completely talking out of my ass on that.
also, factor in the price of a travel case ($$$$).
and i’ve seen recommendations where they say it’s easier to take the cranks off, which is why i went square taper cranks with self-extracting bolts on my own bike.
take a long look at the front rack for packing reasons too.
[quote=halbritt]I think Dimension makes a stem that’s identical to the VO stem.
that’s what i’m saying. vo stem ain’t a bad stem, but it’s not worth what they charge for it when there’s a nearly identical one on the market. iirc, they’re not exactly the same, but not that many dollars worth of difference.
yeah, I think it’s open, I’m not sure what position you’d be going for, but it’d be worth it to send an email I’m sure.
but have you ever been to Ogden?
Commuting from SLC wouldn’t be horrible, especially if you took the train. But that’s a 2.5hr commute roundtrip… Driving wouldn’t be bad, since traffic goes the other way.
Just my thoughts.
