I know this is a topic that has seemingly been discussed ad nauseam but I can seem to find clarity here.
What is my chain line going to be like with A Phil low flange track hub to a set of 75s? Im looking for a perfect chain line…and if I remember correctly this isnt it.
Am I going to run into any issues? Is there a way to achieve a better line with this setup? Im attracted to Phils because of there reputation, sealed cartridges, and looks but would I be better off with something else? Id rather stay away from loose ball.
I was pretty set on this combo. Im getting a White Industries BB that is compatible with the 75s but Id really like to achieve a prefect chainline given that Im kinda going all out.
i have sugino 75 cranks, chainring and bb with a phil wood hub and cog with a sram pc-1 chain and its the quietest bike in the world. I love that drivetrain.
[quote=“carail”]might be a little noisier, maybe just a litle
i have sugino 75 cranks, chainring and bb with a phil wood hub and cog with a sram pc-1 chain and its the quietest bike in the world. I love that drivetrain.[/quote]
Funny, I have the same exact drive-train setup and it’s not all that quiet.
[quote=“zombie”][quote=“carail”]might be a little noisier, maybe just a litle
Funny, I have the same exact drive-train setup and it’s not all that quiet.[/quote]
maybe you have your chain too tight.
that’ll make it noisy. so will a dry chain and a dirty drivetrain.
[quote=“carail”][quote=“zombie”][quote=“carail”]might be a little noisier, maybe just a litle
[quote="(|)"][quote=“zombie”][quote=“carail”]might be a little noisier, maybe just a litle
the problem of the cups loosening.
you could probably solve it with some loctite in your threads but you know i don’t really like the idea of putting loctite in there.
also i think the spindle in mine had a bit of runout.
as far as the bearings…they stayed pretty smooth the whole time i used the one i had.
Please people…having a chainline off by 0.5 mm is not going to effect how your drivetrain sounds. I doubt any of you can even measure your chainline with that sort of precision. Go get a digital calipers and look at how big 0.5 mm is…its not worth even posting about. The sound of your DT has more to do with the amount of lube on the chain and how well you chain and ring/cog mesh.
