wondering…
i need a ulock, a mini one. AND… i’m looking to not spend 60 at my LBS for a krypto evo mini.
So I want something cheap, but still does the job. basically the question is this … onguard bulldog mini VS. kryptonite evo mini.
I read all the threads on BFSSFG, and hear not-so-bad things about the onguard.
I have a bulldog mini and it’s fine. the only trouble i’ve had is the little yellow rubber things would get in the way of the holes for the lock, and ones gotten ripped enough that it just came off. but besides those it’s good.
[quote=“Rusty Piton”]
60bux is way cheeper than a new bike.[/quote]
that’s exactly it, says
I’m looking for a definite reason to chose the kryptonite mini over the bulldog mini. for example, the extra money is it really worth the extra security? is there even more security with the evo mini as opposed to the onguard mini?
a u lock is still a u lock, correct? a thief will have to use the same procedure on either one, or am i wrong?
thanks for the help, by the way, and the quick responses.
I have a Bulldog. My bike as not been stolen in the 2 years I’ve been using it. But there were no attempts on it so I don’t know if this means it’s good or not.
Maybe there’s a bike theft forum out there. We can ask the same question. Most popular lock is the one to avoid.
Same here. I researched this when I bought the lock, and the few tests that I saw actually rated the Bulldog higher than the Evo (as in it buys you seven more seconds against an angle grinder). I think the Evo’s popularity can be attributed almost entirely to Kryptonite’s marketing, because I fail to see how it’s any better than the competitors.
Awesome first hand info, stuff i couldn’t dream to get over at BF. Thanks alot, even for the links…I was just browsing over that auction earlier.
There are still alot of mixed responses, which I didn’t really expect. As of now, I will probably get the OnGuard due to the last few posts. Please keep sharing your experiences.
Also, what did you do as far as removing the metal piece on one side, or taking off the rubber caps on the bottom?
