How much does it weigh?
Definitely looked at em at the PSU bike co-op back in '11 but never wanted to pull the trigger for something that overbuilt.
They were ubiquitous to anyone that porteured things in the late 00s
i won an auction for an orucase b2 for $380. but it was local pickup only. the seller wouldn’t ship. why?? it’s meant to be shipped!
Not sure. Definitely way less than a cetma. Nothing is welded on it apart from the friction welds from some grinding. The fork crown mount seems to be a weak point. I’m thinking of potentially recreating one from steel for ease of mind and to also get a friends rack operable as well.
cheap 105/tiagra/bb7 mini group
Kind of want
rapha stuff 4 dayz
those have weird post placement right? and they take mineral oil right? if no/yes how can i do disc and magura on a splitter from one lever so i can break the headtube off of my clydesdale?
That’s a yes/yes.
what’s the weird post placement?
On the frame I had, the brakes attached to special brazeons with no posts. If @bward1028 still has that frame, maybe he can elaborate.
yeah, it has special braze ons, but they had to make one for normal frames, right?
Yeah the majority out there that absolutely mount to normal canti studs. The kind that go on dedicated braze-ons are usually found on trials bikes.
Edit: in that ad you can see the canti mount holes down low, the release lever on one side to allow wheel/tire removal. And the arch part is a good indication of canti mounting(requires the arch).
Why does that fork exist?!?
