i think this came up even better than wd40 (which beat pb blaster and most other penetrating lubes) when AvE did a highly semi-scientific torque test on freeing nuts and bolts he turned into “get around to it”s by soaking in salt or something. seemed like the biggest factor in how well a penetrating lube worked was hitting it with a hammer though
Now don’t the just use the forklift?
The hammer is the important part: you’ve got little bits of corrosion sticking it together, and you have to break the bond.
it’s rumoured that Kroil is also similar, and it works well if you prefer to buy something. But the hammer is critical. I like to douse it in penetrant, give it some taps while wet, and then repeat a few hours later before attempting to extract.
yep, and apparently great for straightening motorcycle frames too
I successfully freed a seized post in my HG with some photos blaster. I let it sit overnight then just cranked the seat with my arms while straddling the bike
I could do that. Sounds a little too sensible.
Nah. You can’t get a gooseneck like that on all these newfangled bikes
Too excited to not post this. Clearly not done yet, I don’t even have a front brake on it yet. And I’m planning on painting the fork.
I also just realized I have King headsets on all the bikes I actually ride. Including this one. A threadless 1" on a '92 stumpy. Ridiculous.
FTFF
If you left the fork black and got black spacers and a black chairpost it’d look great, with less work.
Fender stays
More like
Fender overstays
is this thing on
yeah other than the fender line that thing is fine. Nothing I would clamor over but… fine
Is that a bontrager fork from one of those cool Gary Fishers?
“Wound up”
Are those brass fenders?
