that is much better than a spiral wrap
Thanks! I want to improve the “keeper” bolt on the inside of the leg but otherwise I’m satisfied. Definitely pulled the trigger on the Cyclefab. A normal Ozette/Peregrine seems useful to me for stuff you need on the bike, but I’d rather carry groceries. Not sure if it’s easier to just buy a light per rack now or to add a new set of connections somewhere to the cable run since I soldered the Son spades on after going through the leg.
Hopefully the swappable legs means I can put it on a low end Jones eventually, too.
Aw this makes me wish the dew had a cross bike A-C so I could accidentally a fork from endpoint and set the wallet on fire with the rack from HC.
different struts! dew has low rider bosses right?
My dew ain’t got shit, and it’s a 411 a-c. That’s the problem, though a 0.5 deg steeper HTA can only help.
Get some di2 stickies to hold the wires.
or at the very least an r clip
yeah u rite, forgot about that stuff
Is good stuff!
The colour matched Searchlight fork is a real treat for the orbs.
Forgive me if this has been asked/answered before, but will wiggle bike have di2 routing?
ive always wanted a wiggle bike but fear i may be too fat for a wiggle bike. pls advise.
no to your first suggestion.
You should get a wiggle bike at least once in your life. And a modern wiggle bike will be better than what I had (A 1980s high end Trek wiggle bike).
I was around 200lbs when I had mine and it was nice and fun, except ghost shifting the downtube shifters when standing climbing from frame flex.
i think im too fat for wiggling but i want to know more!
@EndpointBraden is there going to be a tarck colourway for the new things? do we need to organize a gb?
210 pounds on a wiggle bike cru checking in.
Do it. You will only regret it a little at most.
I want to be clear my wiggle bike was standard 25.4 top tube, 28.6 down tube, Reynolds 531c-tubed frame. It was lovely.
I will be surprised if the Endpoint is made from tubing that wiggly, I expect it to be at a minimum one notch stiffer, but I don’t have much to base that assumption off off.
How on the actual fuck are you 210#? Are you 6’6"?
