Cross racing is awful.
I’m weighing a reverse periodization plan for '23. I’m not sure if I’m going to compete next season, which would make it a good time to fuck around and find out.
We’re looking at another La Nina weather cycle this winter. Less volume would make the outdoor riding a little more tolerable. Also, the build plan I use gets to be pretty exhausting by the end. Evening the training stress out might keep me out of the overtraining band.
I downgraded my smart rollers to dumb rollers. The resistance unit was floating by +/- 20W, which was getting annoying. When I took it off, I noticed one of the mounting posts had broken, which may explain the wandering setpoint.
First FTP test of the 2023 season. ![]()
Did a field test to see if 3.5 days of poopbarning had an effect on my FTP. Seems like it did. Says 13 watts more, but my last FTP was supposedly 243. A bit tricky as I had a downhill between 25 and 30 mins which cost me.
EDIT: This season is bogus. That was actually 2008. That shows you how much you could expect your power to decline over 14 years. I just did a bulk load into Intervals.icu one day.
wasn’t this ride like a week ago? my last ftp test when i was strong was a week after a big tough race and i was stronger than before but people told me it wasn’t representative due to me still recovering from the hard race
Yeah. Exactly a week ago. Maybe I will do another one next week, or not. I am mostly over that stuff. It’s not like I have anything to put fitness towards. Just nerding out for the sake of it : P
Do I want this to pretend I’ll get faster outdoors?
230 EUR is about 50-60 lower than i’ve ever seen previously…I had expected at some point I’d need to spend 3x that for Power2max thingy
i’ve got Shimano non-series 500 cranks on it now, so wouldn’t be that far off.
i would say yes if :
this is the bike you ride most or at least the only one you’ll “train” on. it’s really hard to train with power if you’re not riding a bike with power for a good chunk of your rides (as if not, you cant get an accurate picture of training stress).
you plan on doing some structured training. even without intervals, power still gives you an accurate representation of your training load, but to really improve, you need to follow some kind of plan and do some focus interval training to get you toward your goal. interval training will get you a base line on power and you can quantify your improvements down the road (plus know when to retest FTP when things start to feel too easy or you can overshoot targets).
I found power super useful for sticking to zone2 which is good for training (even if you aren’t doing more aggro intervals) and also for pacing brevets. It’s way faster to be the nerd who doesn’t chase the group up a 400 watt uphill sprint early in the ride, and then later on have all this gas. Power is infinitely better than PE and quite a lot better than HR for keeping you off that kind of stupid effort.
Tldr I would say that if you use this at all you’re going to be faster outdoors.
Thanks for the replies @amy and @Andrew_Andeson
This would def be for the bike I would plan on any long and/or structured rides, so think it fits in that way. I do have a Kickr as well for indoor if I can ever get back to structured indoor training, but that isn’t set up currently as no good place to leave it around babby.
The more common usage I was hoping for is in line with what @Andrew_Andeson suggested - better pacing and evaluating long efforts.
Seems like a good fit. Thanks!
yeah i’d listen to matty. he appears to be a stupidly fast slow rider
I want to ride bikes with you and your club someday
I spent most of November out of state, only getting rides in on the weekends when I was home. I pushed everything out about 4 weeks, with this week being time to get back to work. I lost quite a bit of fitness due to family matters, but less than I expected.
I started off the VO2 efforts with 95+ rpm for this block. I’ll bump it up to 100+ rpm in the next block. The weather is also properly shitty this year; I’m kinda glad I chose to reverse the build and base blocks in the calendar.
229ftp. not bad for basically not riding bikes right now. probably could have hung on for a few more mins but meh
edit: i mean seconds. was a ramp test so a few more minutes would be ludicrous
Yeah i did a ramp test and just kept wanting to quit, then when i did quit i still was not sure that i couldn’t have hung on longer. Plus one the result came back i was like, well fuck, 204 watts?
Then immediately after i did a zwift race and averaged 206w for 24 minutes.
Eh close enough.
i’m totally ok with my result but i might coulda kept going a bit longer. erg mode is a double edged sword
I did a ramp on Saturday morning and got 25X
Just got a pm for rando bike
Tested lezyne to charge during operation and it works
I’m on this 6 week ftp builder and I’m not totally sold on it working in the real world. 200k preride next weekend, i guess we’ll see?
what’s yr watts/kg?
2.7? Now?
FTP/kg right?
yeah ftp/kg
