Not to mention terminal velocity after riding off cliff/jumping out of plane
but does it jump out of plane?
does your
plane while you
on a
flying over a
plain plain (where falls mainly the rain in Spain?)
PS couldnât be arsed trying to shoehorn an astral plane reference in sorry not sorry
1x11 + 1x11 + 2x11 + 2x10 + 1x1 = a total of 65 rideable speeds.
No no no. We need to get more granular here. You might have multiple bikes that have the same gain ratio with specific gear combinations, leading to an overcount. How many unique gain ratios in the stable?
-Next generation statistics.
also consider meters development and crank leverage
5x170mm
5x different wheel/tire combos
not enough 1x1s here. câmon.
my ones are:
1x1
1x1
1x9
1x12
2x11
for a total of 45, with an average of 9 per bike.
sounds like if i just re-distribute, i can have all 9s, trouble will be fitting 2x4.5 on the road bike and cramming 9 gears into the back of the track bike.
1x1
2x11
3x8
2x10
This comes out to 67. The triple really skews things.
id argue the 1x1 is your real outlier. 24 speeds is only 2 more than 22
Now I kinda want to count all the teeth on all my speedz
How teeth do you own?
No kidding
1, 20, 22, 24
One of these things is not like the other one
one of these things just doesnât belong
3x1x1x8 here
no its not some bizarre whyte notation (paging @orc) thats 3 bikes with 1x1 chain drive and 8speeds COMING FORM INSIDE THE HUB
also
3x7
2x7
2x8
2x10
and several Xx0 / 0xX (either no rings or no sprocket) or X_X some number of rings and sprockets but no chain
also not one but two double sided fixed wheels.
my grasp of maths and statistics doesnât allow me to actually use this data to come up with any numbers but its probably 420
UIC(ish) for the win: 3Ă1âAig8
Preliminary stats without gain ratios:
2x9 Falcon
2x9 Crosscheck
2x9 Campeon
2x9 Crossbow
2x9 Leader/Boston Whaler
1x9 p29er
1x9 Fatback
2x10 Swiss Cross
2x8 F1000
1x1 Rush Hour Pro
1x1 Street Dog
1x1 Cinelli weird CX thing
I just saw a mistake in mine so I am redoing.
Pardon my mathsâŚ
4 x (2Ă9), 1 x 8, 1 x (2x7), 1 x 10, 1 x (2x10), 1 x 11
= 127
should we be providing every ratio as well?
You decide your own level of involvementâŚ
In that case, I want to change my answer to: I own bikes good.
