This looks pretty Epic.
Terra Australis
6,400 kms and 62,000 vms
Not a massive field, getting time off work could be an issue !
no ferry leg to Tassie?
What were they thinking ; )
Anybody used one of these as a handlebar bag?
tryna avoid dropping hundreds of $$ on a dedicated bag setup, rather go âfun and flexibleâ
2 x 2 tiedown points and durable material looks pretty good
I made a molle âpadâ that wrapped around a compression sack and used pvc handlebar standoffs. It was fine
No, but iâve been kind of thinking about using one of these. Looks pretty close to basket size and strapping possibilities on each corner.
You will end up scuffing/rubbing through the contract points. Itâs very easy to build up a very basic bag-roll with minimal sewing machine skills. I started with a satchel from a conference. Just cut the back off it. You just want something that the straps can rub on instead of the actual dry bag.
My sewing machine isnât here :â-(
which is a bummer cause I have a whole bunch of XPac sitting around
maybe Iâll yolo it for this trip and sew something for the next one
Planning on something similar using the following link as a visual guide;
I can send you my molle one on Monday when I get back, I never use it.
me? that would be dope. peemd
Yes, Iâve done it, and with one of those bags without tie downs. Itâs not ideal but if you take your time and repack it once or twice so that it fits well youâll be fine. On the handlebars you shouldnât have problems with wearing through.
Iâve only had issues with holes when I used one of those bags lashed to a rear rack while riding in the rain. The grit that got flung up worked its way between the rack and the bag and the road vibrations did the rest.
get me into seat bag + dropper post
will those valais clamps work with any bag or are there some that still wonât work?
rly like the look of these https://rockgeist.com/product/gondola/ but 5 week lead time
I have a Gondola. Kind of small but it is pretty amazing that it works as well as it does. It started to get a bit unwieldy when I hung a 3 person Tarptent off the back of it (quilt and 26+ tube inside, Tarptent at the very back being held by cinch strap alone.
I got it just before my trip a month ago. If youâre interested Iâd sell it to you. I want something that can handle hanging my tent off the back so I think I need to sacrifice some dropper real estate and use a valais clamp.
To answer your question not all bags will work with the clamp. The bag seatpost strap needs to be in the right place and the right size.
Thatâs the bag style Shimano is using (scroll down)
Those new Shimano bags actually look pretty good.
DQ: Whatâs the current state of the art in carrying stuff on bottle bosses?
y not both
