Doing some basement cleaning today I came across the old Tarck edition TB-14s that I commuted on for years. They’re totally roached and not tubeless so they’re going out to the alley for the junk man. I decided to cut out the valve hole badge for posterity. Here’s what I found:
The whole process from idea to creation to badge was pretty amazing to me, and when I hear others recommend them (outside of any Tarck knowledge) is a bonus. Definitely gonna save the badge when mine finally go.
bad news is i have a 6800 crank. good news is i don’t ride that bike and am currently in the dad-chrysalis, getting weaker and weaker before i emerge with the oddly specific and inconsistent but effective when necessary strength that can only be gained through non-cycling related sacrifice
I think it’s pretty unlikely that anyone needs to worry about that sort of failure. Obviously it’s possible, but out of literally thousands or tens of thousands that I’ve seen and worked on, I’ve never seen this happen.
A recall wouldn’t be shocking. As sharp as this one was where it broke the rider is lucky she wasn’t seriously injured.
It’s a pretty terrible design imo. The aluminum doesn’t appear to be treated at all before it is glued together. From what I can tell oxidation starts inside the crank after moisture gets in and starts wreaking havoc on the bond with the epoxy.
They should stop dragging their asses and make a carbon crank already. It’s true they are not without failure, but I’m sure Shimano can make a durable one that’s all the bee’s knees.
Exactly, they’re just being dicks about insisting on this 2 piece forged bullshit. I get it, you have excellent forging capabilities found nowhere else in the industry. Just because you can…
My old boss designed mid-air refuelers for Airbus which were held together with adhesive, and I don’t need to tell you the kind of stresses that sort of application sees. Shimano’s definitely fucked up on a lot of the new Ultegra cranks, but there’s really nothing fundamentally wrong with a two-piece bonded system such as this.
