Thanks. I definitely learned a lesson on that one.
I ended up with one chipped tooth, but just in the enamel, so the dentist says it should be an easy fix.
ooooof. glad you’re not permarekt after that. sounds horrific.
fuuuuuuuuuuuck
Happy you didn’t get super hurt earwig! That’s fukkin gnarly
Jeeeezus!
Yikes! I was expecting worse after that build up. Glad you’re more or less ok.
Brütal! A great reminder to stop before fiddling with front wheel adjacent shit, says the guy who has kicked front panniers back into place and nearly crashed.
Thanks, all. I definitely came away from this one realizing it could have been a lot worse. I was moving 10ish mph on a quiet road.
519JJtut%20rL
no broken bones or teeth is super lucky
I have definitely poked around the pokes and the rear brake while riding to check/yank shit back into place… I might not do that anymore. Thanks for taking one for the team, I guess!
yikes.
the other day i got a piece of tape stuck on my front wheel, instead of stopping and removing the tape, i just frontside ted-shredd’d it off. everything was fine, but…
i won’t be doing that again.
I drag my shoes and gloves on my front tire all the time to remove debris/sharp things. The key is to reach out in front of the fork. I don’t see what the big deal is
Jan has the answer guys.
Wonder if you could create a Tire Wiper with a tiny hand:
I have complete faith in you, Andrew.
only if you can do it with a bunch of orange hands on one blue hand or vice versa
I wonder if those would fit on the shift and dorpper levers on my mountian bikes. Give a tiny high five with my thumb whenever I shift or dorp the dorpper.
I flatted a Horizon in the rain today. I guess my tire soup had dried up. I squirted a little bottle in there and it held until I weighted it and then started loosing air again.
I shoved a bacon strip in there and it worked.
What I’m getting at is that I’m down for a tiny hand tire wiper group buy.
Also for bells
if there were a list of folx with the chops to make that happen, you’d be on it.
Please get something more worthwhile than HN’s.
