There’s nothing more pleasurable than riding a straight block, assuming the riding that you’re doing is within the range that you have.
In circumstances where one might like to have a “fat guy’s double” there’s really not much benefit to having a compact crank except to save the blow to your ego that triple would bring. The only benefit to running a wide-range cassette on a compact is mechanical simplicity and a tiny bit of weight. Maybe you have a double and need lower gearing, then it’d be nice.
For folks that are racing and other skinny dudes, running a compact saves the need to run a wide range cassette to get up certain climbs.
[quote=halbritt]There’s nothing more pleasurable than riding a straight block, assuming the riding that you’re doing is within the range that you have.
For folks that are racing and other skinny dudes, running a compact saves the need to run a wide range cassette to get up certain climbs.[/quote]
Both true. I’m really happy with my 12-23. 36x23 gives me all of it and I haven’t found a hill I can’t climb around here. And if I was racing I could easily put a 52 on there and stay within the magic 16t range that most ft der’s can shift well.
Just switched from compact to standard and mainly I just notice shifting the FD more, so far.
Maybe soon I’ll go compact 50/36 with 11-23.
I’d also recommend 42 with 11-25 for anyone doing 1x10. I’ve been riding it all winter and haven’t found a hill I couldn’t climb yet on my heavy POS cross bike (22.5 pounder), and the top end is high enough that you can sprint if you have the leg speed (and headwind) on your side. Actually, a great training gear range in general because it’ll make you push harder when the grade is 15% or above climbing up, and then spin faster coming back down (if you can muster the motivation to keep spinning and not coast).
