A bad idea we can’t quit. No one else is crazy enough to use so little rubber in a sidewall.
I’ve always been able to mount CX cushes with bare hands. RTFM though.
I find myself underbiking more often lately and is where these problems have manifested. On pavement and light gravel the G-One speed tires are fine.
Lately I’ve been doing a loop from my house that is basically 2-3k rolling feet of XC trails.
Still boggling at how readily they roll at 45PSI though. I occasionally run my 30mm Challenge Stradas that low and those are fine.
The G-One Speeds are all V-Guard-ed now so they have a layer of Turdlon in the casing
I may have accidentally discovered an antidote to drought conditions in California. Order a set of tires optimized for dry conditions and get an unseasonable week of rain in the forecast.
I’m on a pair of G-One Speeds in 35 at ~40psi f/r and I kinda hate them. They grip fine on pavement and light grave, but they just ride like garden hoses. All I want is something as smooth as a RH, I can’t quit them.
My experiment with the paper weight Hutchinson XC tire has come to an end.
I got prob 200 miles before some rocks did it in. Replaced with a Maxxis Aggressor which should play much better with my new local trails.
I like these tires very much. Successfully completed a climb that I dabbed on twice last week for traction reasons. Though it was wet today vs dry then, but I felt way more confident on the seat 45PSI. Eyeballing tire drop, that or ~50 might be right for pavement. I wager 35 is fine for mostly offroad.
I spite of being “dry” tires these worked pretty well in the wet. They also handled a 40mph descent on damp pavement just fine. They feel reasonably supple. Went on reasonably easily, required a compressor to seat. They did seat with little drama after a couple squirts if air. Didn’t have to remove the valve core or any other antics.
Those are the more supple ones too. Sidewalls are a tad thinner than the black/anthracite version. Vittoria doesn’t do the best job differentiating, but you definitely got the best riding ones.
They definitely feel it.
I have heard this about the larger G-ones from a very “unsubstantial” rider.
So I decided to go with Runnies in 55 mm endurance casing and I bought the smart seal shizzle
I will almost certainly regret this
The thing I like about the runnies, apart from the ride, is they go off and on the rim so easily. Probably not a “feature” if you run tubeless tho.
It’s a feature of Panaracer-made tubeless offerings. Go on real easy the first time but will never seat tubeless again.
Yep… takes some special magic to make that happen.
In preparation for my vacation capstone ride I removed my 28 mm Schwalbe TT tires for the winter and popped on some Enve 31 mm tires. When I say popped on I mean it, they went on easy, held air without sealant, and there was no sidewall or bead leaks after adding sealant.
What rims
Look at you, doing tubeless tires with no drama.
All it took was abandoning the absurd attachment to well marketed Panaracer made garbage!
Well coincidentally I just got back from riding those Enves and my god they are awful. I am sure part of it is that I went from literally the fastest or second fastest tire available (Schwalbe TT) to something quite turdly. Enve of all companies should not be making turds.
Nevertheless I am going to leave them on all winter. When I was a swimmer we used to wear loose knee-length shorts over our Speedos for resistance, I kind of have the same theory here, if I ride these all winter and then switch back I’m going to be super fast.
