I bought the cheap carbon Chinese rims and they showed up today. These are the wider 29er rims. I used some Stans Flows 29er rims for comparison. ERD 603
If it’s measures anything like a 45 nomad, it will be in the ballpark of 32 mm. And it may depend on the psi; on my project bike, the 45 nomad + A319 is 43mm wide at ~40psi, 42mm at 60psi.[/quote]
my 35 nomad on tb14s at ~50psi measures to 33mm on the button.
Continental Grand Prix 4 Season 28c mounted on H+Son TB14 after ~500 miles.
Rear @ 85 psi - 27mm wide.
Front @ 55 psi - 26.5mm wide.
Really loving these tires at these pressures. Wish they were a mm wider, but I have heard reports of them growing to 29mm after more mileage. I should mention that they initially measured 1-1.5mm narrower when new.
Width of 28mm Clement Strada LGG (dual compound) on Open Pros: 26.5mm at 100 psi
This is straight out of the box with a driveway spin, will update after a few rides.
Also, here, some good stuff under "specifications (at the bottom). Confirms “flange diameter” listed in above PDF is spoke hole PCD dimension for wheel building. http://si.shimano.com/publish/content/si.html
