I asked them to measure at the shop and they came up with an ERD 5mm different from the manufacturer. But also I watched him do it and I’m not sure he was using the Wheelsmith rods right. They didn’t have the spokes I needed based on his measurement anyway, so I think I’ll have to buy a couple of spokes and measure it myself.
Is zinc anti-seize still the preferred spoke prep here?
i use wheelsmith spoke prep. though i used to just lace them raw and then wick some purple loctite in after taking care of burying the threads on all of them. i think that’s the equivalent to dt spoke freeze
Hey, Imma build up these 650b guys to some DT350s, I’d presumed 3x front and rear, but I was staring at my 700c wheelset and they’re 2x.
They’re 32h, so strength isn’t really an issue. 2x or 3x? Regular spokes are a buck each, blade spokes are almost three bucks each. There’s roughly zero chance of any aero benefit, but I prefer bladed spokes coz windup is easier to prevent. Across 64 spokes that’s like a hundred bucks difference.
I don’t really GAF about a hundred bucks, but that’d still be stupid, right?
but you could do all of one or the other if you have confidence in the ERD, using the two spoke method where you pick your nipple depth that the measurement is set for
I was actually kidding and because I’ve had enough problems getting dish right on the few wheels I’ve built I would have gone with the 2 different sizes…but nothing wrong with getting spokes custom cut
When in doubt round up and use nipples with a taller area at the head. I’ve found that spoke calculators are more prone to come up with slightly short measurements rather than slightly long.
ERD is to “nipple seat”. I added 3mm, 1.5mm per. Actual seat depth for the nipples I’m going to use is 1.8mm. Nipples are Sapim double-square, which adds 3-4mm on top. Lots of room for error.
Based on my previous experience building off of Light Bicycle ERD, this should be about perfect.
FWIW imma yolo these together based on advertised dimensions and I fully expect them to be fine.
Edit: mostly because DT Swiss and LB tend to be pretty consistent about such things.
My favorite, too. It warns against too many crosses, if they’re going to cross near the heads, which would have saved me a lot of work if I’d used it first instead of the othe popular options.
