I can’t use through axles after all, because I use this machine to lug around the bob yak (yeah, the robert axle project sells them, but they are as janky as hell) so lets drag out some ancient can’t be tubelessed unless I’m very patient mtb rims and lace them up to an old deore hub and a baby dynohub instead.
2 hours from pulling the old wheels out to unlace to having them trued but not yet tensioned. Not bad for being out of wheelbuilding shape.
I did that a few months back, a few drops at a time. Seemed to work just fine. It’s dried up a little since then, but it didn’t separate or do anything weird.
Straight pull was the first time having good results with the tensionometer. 4mm on non drive and 3mm on the freewheel side. All the way around.
The front was trickier I free handed it to my acceptable level of true before checking and it was all between 3&3.5. Pulled it all to 3 but it was dished right and walking it back while maintaining consistency is hard. What’s an acceptable ± ?
New line of dyneema rope spokes to compete with Berd, with Goosynn appearing to be coupled to Nextie as an OEM using the same rims at least
It’s using a 4mm interface at the hub to simplify the system like straight-pull carbon spokes do, and looks like it doesn’t have the same stretch issues of needing to keep retensioning after first building
