I like the spesh roubaix 30/32. It’s a very good tire.
fantastic tire. no right to be that good at its pricepoint
I have a pair of tubeless corsas on my bike and they are awesome.
If I buy 33mm Strada Bianca TLRs and they don’t fit my bike will anyone buy them from me? GP5ks don’t seem to be available and are too expensive anyway. I need good not perfect.
I already compromised with black spokes I’m gonna need tan sidewalls.
i probably would
Oh, like that. I can only find it in black.
Knew I should’ve bought a few extra. They were in stock everywhere about a month ago. Anyway:
https://www.bike24.com/p2583623.html
They have some in euroland.
Well Strada Pro 30mm are back in stock at Universal so I pulled the trigger. Little bit of buyers regret not trying to fit 33mm but maybe next time
Just mounted up some Maxis Ramblers in 27.5x1.5 on a wheelset I got for cheap (Fulcrum Racing 700 Disc Wheelset | Chain Reaction - $146 for ~1700g). First time ever that it went smoothly and held air–used the tesa tape bward1028 sent a few years back, and used tubes to really flatten the rim tape. I marred the stickers a bit with tire levers and ape technique, but they’ll see gravel so they’ll get beat regardless.
Why are some tires in this diameter labeled as 27.5 and others at 650B?
It’s only 650b if it comes from a French tire maker, otherwise it’s just a sparkling mountain bike tire.
I need enough tubeless tape to redo a wheelset, should I just buy the $11 roll of tesa 4298 from bezos?
i have a roll left from when i bought 10 that i can send you tomorrow or wednesday
I actually found your old Great Tape Giveaway thread and thought you had long unloaded it all
send me yur address
Only 25 miles so far, but Pirelli P Zero tlr in 30mm feel really good.
replacing a Schwalbe Pro One and Continental GP5k combo, they feel faster and smoother, which is saying something.
Challenge Stradas…where do they fall on the real vs marked size spread? Bigger/smaller than advertised?
Just mounted some 30s on i19 rims. Measure exactly 30mm at max psi.
Pretty accurate to size. 27mm were a touch larger as were 30mm on 28mm rims, which is pretty wide so that’s to be expected.
