There are a TON of 32mm Gravel Kings that were sold as tubeless that absolutely are NOT.
Different bead.
We were sold a bunch that were billed as tubeless by the distributor, by when we actually examined them realized were the same construction as the non-tubeless GKs in smaller width.
I’m not sure if this was ever actually resolved because we haven’t ordered anything smaller than 35mm since.
I did a real fancy dance to get the sealant spread.
The sides of the tires have the TLC designation, and the tire bead shelf feels pretty pronounced. It could be a mislabeled bunch, but it doesn’t seem so?
I let my milk dry out a lot. A tire holds air without being wet IME but it will not seal. That’s when you get a small puncture and are sprinting home on sloppy 10psi wheels.
I have a 20" Hookworm in the clyde fork on my xtracycle.
The tread is like 1cm thick and it’s wire bead and weighs about as much as the fork itself and will probably outlive us all.
Don’t be like me. Don’t buy a Hookworm.
