That's a nice rack thread you had there; shame if something were to happen to it again
I almost forgot — I also moved where the bungies attach to the bag to get a tighter fit that way. However I mainly did that because the bungies were completely loose in the original placement.
Finally had a second to mount up the Rawland Raidoverks on my Elephant.
Went on significantly easier than I was expecting. Did not need to trim straight stays!
Not sure if pure luck or if Sean had them created with the 140-145mm crown hole to braze-on standard that Rivendell / Haulin Colin / Soma / Elephant use. The rubber stay caps barely touch my Ozette.
I made a Luxos mount from a disc rotor adapter and the tidy trimmed wires were juuuuust long enough.
Unfortunately the Rawland rack sits a little bit higher off the tire than the Haulin Colin rack so the stem mounted decaleur doesn’t quite align. I was thinking that maybe I could just add a ~10mm spacer to my steerer to make it align for travel.
If anyone is interested in weight comparison and more detailed photos here i the photo set: Rawland Raidoverks Demiporteur | Flickr
what’s the actual platform measurement? does it feel way sturdy with that style of strut?
Oh man Squirrel I totally forgot about your 3d pull tabs. God damn that’s such a good idea.
yeah when can i buy some of them
Would consume as well.
I think Rentable Faxmachine posted the dimensions on old Tarck, forgot to save them in an email. Can probably measure when I get home unless he saved them somewhere.
I actually emailed Sean about the dimensions approx a month ago, never got back to me :colbert:
I’m not super happy with the bungee pulls right now. They work okayish but not great.
Thinking about starting from scratch and just having a shape more like a single post zipper pull with a flared base.
The final iteration of the pull as it is now is probably the best. I kinda love the spoony shape, it makes it much more ergonomic. Could probably do away with the wings.
I also made these grommet spreader back plates for the pocket flap to stay firm & prevent the pocket from getting all bunchy & taking up the bungee slack in the system.
thing is that I don’t have access to a 3d printer and if I did I don’t know what I’m doing
Our Public Library has 3 and will show you how to use them. It’s kind of amazing.
Getting a timeslot is a challenge.
If only there was a way for him to easily document the dimensions so that others may read them as well…
oh damn, looks like he updated the website: https://rawlandcycles.com/collections/gear/products/raidoverks-demiporteur-rack
Holy crap. I am honestly shocked.
i asked sean about the frame reach on the new sogn twice on ig before they had into listed. i’m now blocked.
finally after… 3 years
also, how does the jawn work with a bag on it? appreciably worse than a fixed strut rack or :man_shrugging:?
Definitely a shruggie right now. Probably not better but also probably not worse.
The matching morakniv is just too fucking much my god
how tall is that tombstone?
Thanks for these photos, you just saved me $80! Was looking at this to replace the Soma portuer on my basketbike, but it totally won’t work.
