Oooh!
We have done a few of those on Sevens over the years. But a reach around from @Orc would be cool too.
Around the side; clearances are better that way as long as you can put up with the hideousness of a steel tube snaking around your fork.
iirc the geo of the frames was tweaked to accommodate the extra thiccness as well
Did they? I thought that was added to Darren’s frame after it had been built
this is the place that makes their carbon forks in 8 offsets each 2-3mm apart
so that they can inanely customize to a 71.7° HTA and 41mm offset
Guilty
Wife’s bike is getting a set of dynamo wheels as some part shifting is going on. B&M lights are out of the budget right now, what’s a tarck approved cheaper option?
I’m not sure what headlights are out there but I’ve set up a couple of these for friends. It’s basically a knockoff of the old Phillips Lumiring rear, great if you are running a rear rack but can be adapted for seatpost mounting.
Looks like you can still get the Philips derived front light from them (but not on eBay anymore I guess) to go with it:
I have one of these and it’s Actually Pretty Good.
Nice work for off-the-shelf parts, but if I’m not mistaken the ewerk doesn’t have a buffer battery in it? (I’ve been poking around looking at buck-boost components for my pile of di2 bikes, and wedging a supercap or battery in is an essential for me. And being able to get the components for under 180€ would be nice, too.)
Is there a dyno front light that hangs from a GoPro mount?
Also, is there a mount for a rear that clamps to the rails of a saddle? Like right up against the seat itself?
I’m trying to clean (dither) up my setup.
Velolumio used to have an expensive seat rail mount that is not showing on their site anymore
This might help?
It’s very easy to mod the IQ-x for this purpose.
Thats the standard klite mount.
just installed a supernova and already regret not forking over the additional $100 for an edelux.
